Гласувай за тази страница в Българския ТОП
Меню
Архив "Новини"
Съкръщения в автомобилната индустрия Печат
02 February 2005
4WD - Four Wheel Drive
4WS - Four Wheel Steering
ABC - Active Body Control
ABS - Anti Blokier System
AC - Air Condition
ACC - Active Cruise Control aktivni
ADS - Adaptive Dämfung System
AGS - Adaptive Gearbox Shift
ALB - Anti Lock Braking
ASC - Automatic Stability Control
ASC+T - Automatic Stability and Traction Control
ASMS - Automatic Stability Management System
ASR - Anti Schlupf Regelung
ATM - Adaptive Transmission Management
AUC - Automatische Umluft Control
AWD - All Wheel Drive
BAS - Brake Assyst
BST - Battery Safety Terminal
CAN - Controller Area Network
CDI -... Diesel Injection (Mercedes-Benz)
CFI - Central Fuel Injection
CNG - Compressed Natural Gas
CVT - Continously Variable Transmission
DBC - Dynamic Brake Control
dCi - diesel Commonrail injection (Renault)
DDE - Digital Diesel Electronics
DISA - Differenzierte Sauganlage sistem
DOHC - Double Over Head Camshaft
DME - Digital Motor Electronics
DSA - Dynamic Stability Assistance
DSC - Dynamic Stability Control
DSTC - Dynamic Stability & Traction Control
dTi - dizel Turbo intercooler
DTI - Dizel Turbo Intercooler
EBD - Electronic Brakeforce Distribution
EBV - Elektronische Bremskraft Verteilung
ECU - Engine Control Unit
EDC - Electronic Damper Control
EDC - Electronic Diesel Control
EDS - Elektronische Differencialsperre
EFI - Electronic Fuel Injection
EG - European Gas
EGR - Exhaust Gas
EMC - ElectroMagnetic Compatibility
EPS - Electronic Power Steering
ESP - Electronic Stability Program
ETC - Electronic Traction Control
ETS - Electronic Tracion System
EV - Electric Vehicle
FDR - Fahr Dynamik Regelung
FFV - Flexible Fuel Vehicle
FIRE - Fully Integrated Robotized Engine
F.I.R.S.T. - Fully Integrated Road Safety Technology
FPS - Fire Protecting System
GDI - Gasoline Direct Injection (Mitsubishi)
GPS - Global Positioning System
HDC - Hill Descent Control
HDi - Diesel injection (Citroën, Peugeot)
HP - Horse Power
HPi -... ... injection
i, I - Injection direkten vbrizg goriva
IC - Inflatable Curtain
ICIM - Individual Control Intake Mainfold
IMS - Instant Mobility System
IRD - Intermediate Reduction Drive
ISOFIX - International Standard Organization FIX
ITS - Inflatable Tubular Structure
JTD - uniJet Turbo Diesel turbo dize
KW - Kilowatt
MPI - Multi Point Injection
NGV - Natural Gas Vehicle vozilo na naravni plin
OBD - On Board Diagnostic
PDC - Park Distance Control
PES - Poli Elipsoid System
PPD - Passenger Presence Detection
PRS - Programmed Restraint System
SIPS - Side Impact Protection System
SDI - Standard Diesel Injection
SMH - Societe de Microelectronique et d'Horlogerie
SOHC - Single Over HeadCamshaft
SPI - Single Point Injection
SRS - Supplemental Restraint System
STC - Stability & Traction Control
TC - Traction Control
TCS - Traction Control System
TDI - Turbo Diesel
VANOS - Variable Nockenwelle Steuerung
VDC - Vehicle Dynamic Control
VIS - Variable Induction System
VTEC - Variable valve Timing and lift Electronic Control system
VVT - Variable Valve Timing - intelligent
WHIPS - WHiplash Protection System
WET W - Engineered Tread
< Предишен   Следващ >
Най-четено
Анкети
Планувате ли да си купите чисто нов автомобил през следващите 2 години?
Прочетете и...
Банер-ротатор
Best view 1024*768
CLUB FORD BULGARIA © 2006 - Host by NOC.bg
